Johndanese
Dec 03, 2020Aspirant
NETGEAR Nighthawk R7000 WiFi Router - LAN gone
I wanted to set up my router for a Mixing board. I went to the settings on browser and updated the Mixer for the LAN IP address 10.10.2.1 The video I watched further stated to change the DHCP start...
Johndanese
Thank you.
I did do a reset -pushed Reset Pin in for 30 seconds, let router reboot. Unfortunately, the LAN options are still not available. When I went to “advanced” then chose “LAN Settings” I was able to look at the screen I uploaded and config it if needed.
That option is no longer available because when I click it the screen refreshes and does not go to the page to adjust LAN but displays a status page for - Wireless, Internet, USB, Parental controls. It does not display the LAN settings as before.
This router will not need to connect to the Internet. It is merely a wireless router to control the mixer and let band members connect wirelessly to adjust their monitors. The internal wireless router is usable but on a stage would sit down too low to be effective - the external router is recommended so it can be placed in a better line of sight for the devices. It will not have an internet connection.
I apologize for saying I “Think” it only resets passwords for access - but I drew the conclusion that it kept the news firmware, made me redo passwords and did NOT bring back the LAN settings adjustment screen.
It is pretty annoying and it is frustrating.
It ONLY comes down to this regardless of what application I was trying to do as I never continued the mixer connection:
I changed the “starting IP to .5 and on reboot the LAN options are gone.
So maybe o have too much info?
The question is why after changing the “starting IP” to .5 did the LAN options go away?
Thanks
Thanks
michaelkenward
Dec 03, 2020Guru - Experienced User
Ah, that's alien territory to me. Netgear designed the R7000 to be a router for people connected to the Internet. I doubt if they considered your scenario.
You may be trying to use it for something that it is not designed for. So there's not much that Netgear, or anyone else, can do to repurpose the R7000.
You might get better help in a group that helps bands to manage their technology. There is thing special about the R7000. Any advice you can get on any router might well carry over to your device.
- JohndaneseDec 03, 2020AspirantNo, I believe it can serve as a router as well as a WAN modem. The only difference is I won’t be plugging an internet connection in. It should still let me connect wirelessly to the network.
It’s a simple protocol it’s just that the LAN info disappeared. Haha. It’s crazy. - antinodeDec 03, 2020Guru
> The screen shot shows the firmware version. [...]
Typing that was easier than typing "V1.0.4.30_1.1.67"? Which, by the
way, is pretty old.> The screen shot shows the firmware version. I did the firmware upgrade
> prior to doing anything. Latest version.Huh? "prior to" taking that picture? As always, an actual version
number would be more useful than your opinion of what's "Latest" today.
> [...] the address was 10.0.0.1 (see picture). [...]That's the LAN IP address of the router.
> [...] Connected to what?
Still a mystery. The fact that the router's LAN IP address is
"10.0.0.1" suggests that you've connected its WAN/Internet port to some
other (unspecified) router. Cascading multiple routers can cause
multiple problems.> [...] the ONLY thing I changed on the router. I changed that to
> 10.0.0.5 [...]_What_, exactly, did you change where? Did you configure that as a
static address _on_ your mixer, or did you configure a "Reserved
Address" for your mixer _on_ the R7000?> [...] to avoid conflicts change the starting IP address to something
> higher to avoid conflict. [...]Ok. Your picture doesn't show that. It's still ".2" - ".254" there.
> [...] I changed the Starting IP address on the DHCP server to 10.0.0.5
How, exactly, would that avoid a conflict? If you configured
"10.0.0.5" as a "Reserved Address" for your mixer _on_ the R7000, then
there's no problem (and you didn't need to change the DHCP pool limits).
If you configured "10.0.0.5" as a static address _on_ your mixer, and
you left "10.0.0.5" in the DHCP pool, then there's (still) a potential
conflict. To avoid a conflict with "10.0.0.5", the pool "Starting IP
Address" would need to be at least "10.0.0.6".> Now I have no access to LAN settings ( the screen in picture). That is
> the issue. It's gone.Where did you look for it? It's not the default screen. Did you try
clicking on ADVANCED > Setup > LAN Setup?
> When I went to "advanced" then chose "LAN Settings" [...]"V1.0.4.30_1.1.67" is so old that I can't be sure what's true there.
On any recent firmware cersion, I'd expect ADVANCED > Setup > LAN Setup
to be the path. As explained in the R7000 User Manual.
> [...] Get the User Manual. Read. [...]Did you?
> This router will not need to connect to the Internet. [...]
Ok, but, as explained above, it does seem to be connected to
something now. It might help if you explained what you actually intend
to do, rather than trying to hide as much detail as possible, confusing
everyone.> I changed the "starting IP to .5 and on reboot the LAN options are
> gone.I doubt that that change made the difference. A much newer firmware
version might have moved the LAN Setup page to a different place.> So maybe o have too much info?
I sure could use more.
> The question is why after changing the "starting IP" to .5 did the LAN
> options go away?That's certainly _a_ question. Look in the right place?
> The video I watched [...]> I spent hours , [...] , scoured internet.
Like "I saw it on the Internet", none of that conveys any useful
information.
> Internet. I doubt if they considered your scenario. [...]
Some of us don't get out much. People do this frequently. The
biggest problem normally is that the router expects to set its date+time
from a network NTP server, and it can't talk to one if its WAN/Internet
connection is missing.> [...] as well as a WAN modem. [...]
An R7000 is a router, not any kind of modem.
- JohndaneseDec 03, 2020AspirantOk thanks for your critique of my question that was helpful (NOT).
Anyway, I’ll ask someone who may know the answer.
The question again is this.
If I go into the router config page advanced settings and choose to change the starting IP address will it make the LAN config page go away? It did. That is all I did.
The support page for the router had that version of firmware as the most recent.
Anyway. Thanks for trying. The answer is you don’t know.- antinodeDec 03, 2020Guru
If you actually want help, then you might want to consider providing
a better problem description. Sadly, that might include answering basic
questions about what you're doing, and what happens when you do it. For
example, a good start would be:> Firmware version? Connected to what?
> If I go into the router config page advanced settings [...]
Exactly _which_ page? Exactly _how_ did you get there?
> [...] and choose to change the starting IP address [...]
This is the "LAN Setup" page? As in "ADVANCED > Setup > LAN Setup"?
Notice that you didn't actually say that.> > [...] Get the User Manual. Read. [...]
> Did you?So, that's a "No"?
> [...] will it make the LAN config page go away? [...]
Not in my experience, no.
> It did. That is all I did.This must be some new meaning for "all". What happened to that
"Latest version" claim in your original message? "V1.0.4.30_1.1.67"
certainly is not even close to any "Latest version" for an R7000.
What do you think that "A router firmware upgrade is available." (as
in your picture) means?> The support page for the router had that version of firmware as the
> most recent._Which_ "The support page for" _which_ "the router" said that _which_
version was "the most recent"? Look for "Model" on the product label.Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:When I do that for an R7000, I see "V1.0.11.110_10.2.100", not
"V1.0.4.30_1.1.67".> [...] The answer is you don't know.
I have no trouble at all in finding ADVANCED > Setup > LAN Setup on
_my_ R7000.With my weak psychic powers, I certainly don't know what you're
seeing or doing. What you're saying/writing makes very little sense,
and you seem unwilling/unable to answer simple questions about basic
facts. Until that changes, I'll look for more productive ways to spend
my time.
