MoniBinis
Jul 26, 2021Follower
Netgear Nighthawk R7000
bought this device 5 months ago and has been such a disappointment. worked fine, great speeds but out of the blue random reboots, or wifi devices no longer getting internet but devices are connected to wifi of the router.
have tried fw update and didnt solve my problem, have tried fw downgrade and same result. anyone else sees these issues with nighthawk r7000 series?
more importantly, what would you guys recommened for basic home router, with wifi services..went from a linksys to a netgear.
1 Reply
what actual firmware version are you on and what ones did you try?
What modem/gateway is it connected to?
after the firmware changes did you try a factory reset?
