Datanetman's avatar
Datanetman
Netgear nighthawk R7000
Hello,
I have problem with connection to web interface of my router Netgear nighthawk R7000 (AC1900).
Router has static IP (192.168.0.10)
After restarting it is possible to connect and configure router via web interface on 192.168.0.10
After couple weeks it is not possible any more until router is restarted.
Internet connection for WiFi users works all the time.
I was not able to find solution of this problem. Any ideas?
Thanks in advance.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    I recommend using 192.168.0.1 and setting the DHCP IP address pool range to .100 to .200.
