MrBigmanforlum
Mar 29, 2024Aspirant
Netgear nighthawk r7000
Hello everyone,so I have a problem with my netgear nighthawk R7000 is that it works in ap mode and it keeps frequently turning off the wirless mode, tried everything it will turn the wirless mode off ...
Kitsap
Mar 29, 2024Master
MrBigmanforlum wrote:
Hello everyone,so I have a problem with my netgear nighthawk R7000 is that it works in ap mode and it keeps frequently turning off the wirless mode, tried everything it will turn the wirless mode off and to turn it on I have to push the button on the router to turn it on
Does it turn off the Wi-Fi at the same time each day?
Does it turn off both the 2.4 GHz and 5 GHz radios at the same time?
When the Wi-Fi has been turned off, do you still have internet access through the Ethernet ports?
There should be a configuration setting to turn the Wi-Fi on or off on a schedule. Look under the Advanced Tab -> Advanced Setup -> Wireless Settings.
