MrBigmanforlum
Mar 29, 2024Aspirant
Netgear nighthawk r7000
Hello everyone,so I have a problem with my netgear nighthawk R7000 is that it works in ap mode and it keeps frequently turning off the wirless mode, tried everything it will turn the wirless mode off ...
michaelkenward
Mar 29, 2024Guru - Experienced User
Can you explain? What do you mean by "wireless mode"? That's not a term I see used here much, if at all. Routers are usually either in router mode or AP (access point) mode. There is no "wireless" mode that I know of. Some routers have a "bridge", or repeater, mode. The R7000 does that. But it isn't AP mode.
Are you saying that the wireless on the R7000 just turns itself off for no known reason? What happens? The wifi LED goes off? Wifi clients lose their connection?
What router sits in front of the R7000?
MrBigmanforlum
Mar 30, 2024Aspirant
Yeah the led goes off
- michaelkenwardMar 30, 2024Guru - Experienced User
And the other questions?
