sierra7's avatar
sierra7
Netgear Nighthawk R7000
Hello, I am a novice at this so please explain in simple terms so that I may follow - Thanks I have a Xfinity XB7 modem connected to a Nighthawk R7000 with an Ethernet cable. I have pinged and found...
  • sierra7's avatar
    sierra7
    Jun 05, 2024
    Thank you very much for your reply and assistance.  My situation is this;
    I want to install a VPN.  My research (as limited as it is) indicates I have to flash the R7000  with DD WRT in order to obtain an open VPN.  It appears that can not be done with the XB7.  Any assistance or suggestions would be greatly appreciated.  Thank you!!!  Bob
