rjm65
Sep 21, 2022Aspirant
Netgear Nighthawk r7000p 5g issues
I recently bought a renewed Netgear Nighthawk r7000p on amazon, the router works great, however there is a minor issue that is quite annoying, I use the 5g daily on my cell phone and tablets to conne...
Sep 21, 2022Guru - Experienced User
What firmware version are you on?
What modem/gateway is the router connected to?
- rjm65Sep 21, 2022Aspirant
The Modem is provided by the cable company, it is an Arris TM-722, the router has firmware version v1.3.2.126 hope this helps...
- plemansSep 21, 2022Guru - Experienced User
Did you try a factory reset and reinstall? The R7000P has had quite a few factory updates. It could be an old setting causing issues.
well since it arrived exactly 2 months ago, the answer is no I have not done a factory reset since i got it... i would assume when i reset it the first time it would be up to date as of 2 months ago, have there been many updates in last 2 months that i should consider another reset?
