Vigon61
Jun 13, 2023Aspirant
Netgear nighthawk r7000p Internet speed low compared to a different router on the same line
Netgear nighthawk r7000p Internet speed low compared to a different router on the same line The ISP provided speed is properly available when connected with different router but the same speed is...
- Jun 15, 2023
Please mark this thread as resolved so others can benefit from the discussion.
Kitsap
Jun 14, 2023Master
Vigon61 wrote:Netgear nighthawk r7000p Internet speed low compared to a different router on the same line
The ISP provided speed is properly available when connected with different router but the same speed is not coming on the Netgear router. Restarted the router, Factory resetted the router, firm is up to date, tried to install previous version of firm and try didnt work.
Can any one suggest what could be wrong
What device are you using to test throughput? How is this device connected to your Netgear router? Via an Ethernet cable of via Wi-FI. How do the various Wi-Fi settings on your different router compare to the Wi-Fi settings on your Netgear router. Are you using the same frequency band, 2.4 GHz vs 5 GHz, the same channel?
Is this unknown device perhaps running Windows? If yes, is the network profile for your Netgear network set as public or private. It should be private at home.
