Vigon61
Jun 13, 2023Aspirant
Netgear nighthawk r7000p Internet speed low compared to a different router on the same line
Netgear nighthawk r7000p Internet speed low compared to a different router on the same line The ISP provided speed is properly available when connected with different router but the same speed is...
- Jun 15, 2023
Please mark this thread as resolved so others can benefit from the discussion.
Vigon61
Jun 14, 2023Aspirant
I Have tried the speed test both on ethernet connected to PC and Wifi on 2Ghz as well as 5ghz.
I had a service man from ISP visit my house to check the settings and he had a spare router he checked the speed via his router, it worked well with full speed on his router even both router had the same settings.
And My PC network is set to Private Home network.
Kitsap
Jun 14, 2023Master
Vigon61 wrote:I Have tried the speed test both on ethernet connected to PC and Wifi on 2Ghz as well as 5ghz.
You are going to have to put some numbers on what you consider low.
Use the Ookla installable test application available from the play store. Do not use a web browser with a test site web address, do not use an internal test feature on a router or modem.
Start off with what is the brand name and model number of the modem that is connected upstream of your R7000P?
What is the throughput capacity you purchase from your ISP? Up/down in Mbps.
With the R7000P, what are the test results from your PC connected via Ethernet cable? Up/down in Mbps.
With the R7000P, what are the test results from your PC connected via 2.4 GHz Wi-Fi? Up/down in Mbps.
With the R7000P, what are the test results from your PC connected via 5 GHz Wi-Fi? Up/down in Mbps.
- Vigon61Jun 15, 2023Aspirant
Thanks for taking time to respond to me.
I finally was able to fix the issue, i did had to logout from my ISP account and update the router to latest firmware again and reset to factory settings and log back to ISP account for it to work. Not exactly sure though was the log out and login of ISP worked or update and reset of router worked or combo of it worked, but its back to the ISP speed of 150Mbps now (it was running at 20 Mbps during the issue).
- KitsapJun 15, 2023Master
