Krod-Nov
Nov 09, 2021Aspirant
netgear nighthawk r7000p wan speed slow
I have a Netgear Nighthawk R7000P and the WAN port seems to be fixed at 100 Megs in the settings. I recently upgraded my speeds through my ISP from 100 to 300 MEGS. I plugged my laptop directly to my...
Nov 10, 2021Guru - Experienced User
Try changing the eternet cable. I've seen sketchy cables that'll connect at gigabit speeds on pc/laptops but only 10/100mbps on routers.
