jraza
Jun 05, 2021Tutor
Netgear nighthawk R7300 Wan port not working
Hi all. New here. R7300 Wan port is not working. Beside Wan port, all other functions are fine. Problem is how to connect to internet. Can we use Lan as Wan? Any converter / adapter. Sor...
Jun 05, 2021Guru - Experienced User
Reason I ask is if that "broadband connection" happens to be a gateway with its own integrated router solution, you could use that as the router. Then run the r7300 in access point mode and wire through the wan port.
Your other option is if you go to its ip address and add debug.htm to the end, some of the older firmwares had a "mirror wan port to lan port 1" option.
so it'd be 192.168.1.1/debug.htm
(replace the ip address with what yours is)
You could always try that option as well.
jraza
Jun 05, 2021Tutor
Thank you for you time and effort for helping me out.
Your first method I have had already checked. It's not working.
Second method I will check on Monday coz I forget router at my office.
Thanks again for the help
