GrifRD
Feb 15, 2025Aspirant
Netgear Nighthawk R7500 v2
So I am having problems connecting my vr headset to wired connection but do I need a wired connection? In order to play my steam Games it was asked once before but nobody replied back. Any help or sug...
Feb 15, 2025Guru - Experienced User
its fine to leave the password the same. But you should be able to view what the 5ghz band ssid is from that screen. That'd be the one to connect your occulus to. Might still struggle on 5ghz as thats an older router connecting to one of the newest VR headsets.
GrifRD
So the
Nighthawk X4 R7500v2
is not the router to have what router do you suggest? For playing on Airlink....?
