BuckGuy
Nov 24, 2020Tutor
Netgear Nighthawk R7960P Not Allowing Full ISP Speed
I recently increased my Internet speed through my ISP to 500 down / 50 up, but my Netgear Nighthawk is throttling my download speeds. I'm maxing out at about 300 Mbps down. Upload speed is fine. P...
Nov 24, 2020Guru - Experienced User
Did you ever try a factory reset and clean reinstall? (not from backup)
Try that first. During the install, make sure to leave qos, traffic monitoring, parental controls, and access controls disabled.
BuckGuy
Nov 24, 2020Tutor
I'll try that, thanks. Appreciate the reply.
