brennan2973
May 04, 2022Tutor
NETGEAR Nighthawk R7960P wifi slower on devices than is says on the app
Hello, I recently got one of these used. I 30, 30, 30 reset it and set it up for my son. After setup, when I run a speed test through the Netgear Nighthawk app, I get 450+ Mbps. When I connect throug...
- Jun 15, 2022I had similar issues. Via wifi i was only pulling 50mbps. But through wire ir app i was getting 300+. I enabled the Smart Connect function in the app. It did some reset on the router. And now im pulling close to 300mbps via wifi on my phone
May 04, 2022Guru - Experienced User
Are you testing over wireless?
Reason I ask is if you're testing using the nighthawk app, it hosts the test on the router.
When you test the speed in your browser or using the speed test app, usually the bottleneck is the wifi you're testing over.
What actual wireless card are you testing on?
Are you testing over the 2.4ghz or the 5ghz? (hint, 2.4ghz is much much slower and sensitive to interfernce)
brennan2973
May 04, 2022Tutor
I will try and give as much additional information as I have right now specifically because I will not return to my son's house until tomorrow.
The modem is a Spectrum issued Sercomm ES2251
when I installed the router, it said it was searching for firmware updates, it found and installed the latest update I assumed.
The only devices that were installed and tested were
1) the Spectrum modem
2) the router in discussion
3) Iphone 13 Pro Max
4) Acer G3-571
- this router was first tested using the netgear nighthawk app on a iphone 13 pro max, the app gave me a speed of 450 Mbps. I then tested all 3 bands on a speedtest.net app and got 80 Mbps on 2.4ghz and 140 Mbps on both 5 ghz frequencies. Originally, it was tested without smart connect but once I was concerned with the speeds, I tried to enable smart connect which yielded the same results of 140Mbps as it defaulted to the 5ghz. I fiddled with this on the iphone quite a bit at first only because I could not get it to open on my laptop (Acer G3-571). I eventually got my laptop to connect on 192.168.1.1 after, I went to speedtest.net and got the same results as on the iphone. I only had 1 device testing at a time, this is my son's first home and nobody is currently living there so it was only me testing. I did see a number (roughly 10 or so) other networks in range. I also tried the speedtest app for windows as I remembered reading somewhere that speeds over 100 Mbps are not always correct with the website and that the app is recommended for higher speeds.
-I then decided to do what I know the ISP would say and bypass the router and just hook my laptop directly to the modem. In doing so, my results at speedtest.net were >450 Mbps. Hence my leaning towards the router or it's configuration being the issue.
-I know wired is preferred, in a perfect world, I would have a wired connection everywhere. This house was built in 1906 with plaster walls and wool insulation. Wiring this house will not be something I will attempt. I wanted a decent wifi because of this and when I came across this router, it seemed to fit the bill.
-the channels were default to auto as far as I know. I did not do any adjustments in the configuration on the router page except accepting the free trial of the security software. I declined disney circle.
-the wireless card on the computer is Qualcomm Atheros QCA61x4A Wireless Network Adapter but it yielded the same results as the iphone 13 pro max.
I think I covered everything. This is a used router that I found at goodwill so I am leaning more towards the router being the problem but I figured I would reach out to people that know more than I for help before I throw in the towel and just buy some brand new TP link or something cheap as my son's budget is small.
Again, thank you for any and all help, it is really appreciated.
- plemansMay 04, 2022Guru - Experienced User
Check to see what actual firmware version you're on. I've seen the auto-update not be on the latest version.
And if you did setup and then update, try the factory reset again. But check the speeds with everything setup with the defaults and test.
Also, try enabling ipv6
- brennan2973May 05, 2022Tutor
current firmware V1.4.3.88_1.3.50 and it states there is no newer firmware. I was unable to turn off the shield becau getting the same speeds.current firmware V1.4.3.88_1.3.50 and it states there is no newer firmware. I was unable to turn off the shield because when I try to enter the security tab it says "Error One or more parameter is missing or empty" and will not let me in. Still getting the same speeds.
- FURRYe38May 05, 2022Guru - Experienced User
Got a screen capture of this error your seeing?
Do you have WiFi Private Address enabled on the iPhone? If so, disable it.
