brennan2973
May 04, 2022Tutor
NETGEAR Nighthawk R7960P wifi slower on devices than is says on the app
Hello, I recently got one of these used. I 30, 30, 30 reset it and set it up for my son. After setup, when I run a speed test through the Netgear Nighthawk app, I get 450+ Mbps. When I connect throug...
- Jun 15, 2022I had similar issues. Via wifi i was only pulling 50mbps. But through wire ir app i was getting 300+. I enabled the Smart Connect function in the app. It did some reset on the router. And now im pulling close to 300mbps via wifi on my phone
May 05, 2022Guru - Experienced User
Follow this if you try a reset and setup using the NH app.
You might try the web based setup first. Up to you though. Were seeing varied problems recently with the NH app. 😒
Nitto52j
Jun 15, 2022Aspirant
- FURRYe38Jun 16, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
