Richie-IT
Apr 29, 2022Tutor
Netgear Nighthawk R8000 - Limited Internet speeds and connection drops
I have been using the Nighthawk R8000 with no complaints until a few months ago. The main issues were pages not being displayed. DNS not being found and internet connection drops. The Setup - ...
Richie-IT
Apr 29, 2022Tutor
The models are
Netgear Nighthawk Pro Gaming XR500 - AC2600
and
Netgear Nighthawk AX6 - AX5400
So the AX6 would be the better of the 2 and should get over 500mbps with access control on ?
Apr 29, 2022Guru - Experienced User
AX5400= do you mean the RAX50?
If so, it should. I'd still check out a few reviews to see how it performs.
I'm a fan of Dong Ngo (dongknows) reviews as he does a great job, isn't paid for it (buys his own products) and even will refuse to review products. Theres a few other good sites too. I used to be a huge believer in smallnetbuilder but there isn't much reviews on there anymore for newer devices.
Netgear RAX50 Nighthawk AX6 AX5400 Review: A Valuable Wi-Fi 6 Router | Dong Knows Tech
If you don't mind renewed, do a quick search on amazon for netgear renewed products. there's been quite a few on there and you can always buy an aftermarket warranty and still come in pretty darned low for price.
