spirittalk
Jan 25, 2021Guide
Netgear Nighthawk r8000 slows wired connection
Hello. I have a Netgear Nighthawk r8000 wireless router that is cutting the speed of a wired connection from 950Mbs to 250Mbs. I recently switched to Ziply Fiber Gig Speed. When they did the sw...
- Jan 28, 2021
Thanks for the advice. The factory reset worked and now getting 905 down and 820 up. Firmware says it is V1.0.4.68_10.1.75. The ONT is Frontier I-211M-L. Appreciate the help! Thank you so much!!
spirittalk
Jan 28, 2021Guide
- plemansJan 28, 2021Guru - Experienced User
glad it worked!
