Sarge34
Sep 20, 2021Guide
Netgear Nighthawk R8000 updated firmware and I get error messages when trying to open a webpage
I just updated the firmware of my router yesterday. Prior to the update, I was not have connectivity problems. Now, using Chrome, I try to open a webpage and I get this message, This site can’t be ...
- Sep 20, 2021
let me know if it works
Sep 20, 2021Guru - Experienced User
What version of the firmware are you on?
Theres been some dns issues on the later version (or 2).
Try installing version 1.0.4.68 and see if it works.
- Sarge34Sep 20, 2021Guide
Thank you for the message. It updated to V. 1.0.4.76. I will take your advice and try installed an older version. Thank you again for the message.
