KenKul
Nov 16, 2016Tutor
Netgear Nighthawk R8000 VPN Pass-through
Hoping someone has a solution for me. I have a R8000 netgear nighthawk X6 router at home. It works perfectly with all my devices except my laptop for work. There are times where I have to work fr...
- Nov 17, 2016
Hi KenKul,
Try adding the IP address of the device where the VPN software is installed under the DMZ setting of the router. If still the same problem, try connecting the device directly to the modem and check if that works.
JamesGL
Community Team
KenKul
Nov 22, 2016Tutor
Awesome, that works. Thanks JamesGL
Cheers
Cheers
JamesGL
Nov 23, 2016NETGEAR Employee Retired
Hi KenKul,
You are welcome!
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
