nmpth
Jun 21, 2017Tutor
Netgear Nighthawk R8000 X6 AC3200 - SLOW speed over wifi
Hi All My ISP just upgraded my internet connection to 200 Mbps(DL)/35 Mbps (UL) -- prior to this upgrade my internet speeds were 60 Mbps (DL)/ 25 Mbps (UL) As a part of the upgrade, they sent...
- Jun 25, 2017
Hi nmpth,
Update the firmware of your R8000. Reset the router to factory default after the update and reconfigure it manually.
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
JamesGL
Jun 25, 2017NETGEAR Employee Retired
Hi nmpth,
nmpth
Jun 26, 2017Tutor
Hi JamesGL
Thanks for reply.
I already have upgraded FW to V1.0.3.46_1.1.32 when i connected my new modem.
In that case -- do i only need to factory default my R8000? Also, how do i revert my router to factory default?
Best Regards
- JamesGLJun 26, 2017NETGEAR Employee Retired
Hi nmpth,
Just press the reset button at the back panel of the router until the power turns amber.
