Topher_cug's avatar
Topher_cug
Netgear Nighthawk R8000 X6 AC3200 slow FTTP speed
Hi all,
The Router is just over 3 months old and worked flawlessly with my old FTTC connection.
We have just upgraded to the FTTC 900 connection and the Netgear router seems to have capped speeds at 300-350
The ISP supplied cheap router gets 750 can anyone explain why this is happening and suggest any potential solutions? Thanks in advance.
  • plemans's avatar
    Make sure qos, traffic monitoring, access control, and parental controls are all disabled and reboot the router.
    If they were ever enabled and the disable/reboot doesn't fix it, try a full factory reset and clean install (not from a backup).
    Try that first.
    • Topher_cug's avatar
      Topher_cug
      Thank you for your reply - I have checked your suggested settings and they were not enabled. I performed a factory reset and checked the settings again unfortunately it is still displaying 300 - 350 mb speed which I cannot for the life of me understand. Any further suggestions would be greatfully accepted.
      I cannot understand why a router that is the third of the cost of this Netgear router is performing full speed around 800mb.
