LOISLANE
Aug 05, 2020Initiate
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Ro...
- Sep 23, 2021
I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
dvs_xerxes
Aug 08, 2020Guide
I have the same problem, Firmware verison still shows V1.4.1.50_1.3.10 after after doing a manual update of V1.4.1.62_1.3.22.
Ive tried doing a factory reset then updating, but it still doesnt show that it was updated.
kye4u2
Aug 11, 2020Initiate
I have the same issue. I've attempted to manually upgrade to 1.4.1.62 from V1.4.1.50_1.3.10 but it still continues to display V1.4.1.50_1.3.10
