LOISLANE
Aug 05, 2020Initiate
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Ro...
- Sep 23, 2021
I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
malssid
Aug 16, 2020Star
YEP, unzipping it, pointing to the .chk file and doing it manually from my ethernet connected computer!
dvs_xerxes
Aug 16, 2020Guide
I still have no luck, I tried it again with the router with all devices diconected including modem. and only had a laptop only connected via ethernet by port 1 it self to do the update. I even try doing a factor reset too before updating. The router would go through the motions of acepting the update with the chk file, progress bar moves to the right, get message its rebooting.. But afterwards it still shows that V1.4.1.50_1.3.10 is running.
- shadowsportsAug 16, 2020Hero
Greetings,
Using TFTP is another option for firmware update. This is normally used for recovery, but you can perform an upgrade/downgrade as well.
- dvs_xerxesAug 17, 2020Guide
I tried to do the TFTP method today using the
windows tftp method
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
and the tftp client method.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
both methods failed and my router is still running version 1.4.150_1.3.10
I also notice that there is a discrepency on step 6 of the second method(client tftp) "Turn router OFF for 10 seconds and then turn it back ON." and on step 7 and 8 of the first method windows 10 tftp client. (Hold down the reset button on the back of router with a paper clip and Power ON the router while holding down the reset button."
I tried each method and it didnt work.. On a side note I was able to back up and restore my configuration settings using the routterlogin.net webpage, so i know that my web browser is working uploding a file just fine.
- AndreCarrarettoAug 18, 2020Aspirant
I was able to upgrade normally as I had already moved from 1.4.1.50 -> 1.4.1.56 (beta). From 1.4.1.56 to 1.4.1.62 was a normal (no errors) upgrade.
- shadowsportsAug 18, 2020Hero
AndreCarraretto wrote:I was able to upgrade normally as I had already moved from 1.4.1.50 -> 1.4.1.56 (beta). From 1.4.1.56 to 1.4.1.62 was a normal (no errors) upgrade.
Same for me as you already know.
- shadowsportsAug 19, 2020Hero
I've escalated this topic to the moderators for investigation.
- DR650SESep 15, 2020Guide
This is such garbage on Netgears behalf. Why is this problem not solved and Why has Netgear refused to comment? The current firmware cuts my speed in HALF from what I should be getting and has serious QoS issues!
- malssidOct 14, 2020Star
Problem STILL not solved. Honestly **bleep** netgear and their **bleep** customer support. I can't update manually or automatically to the latest firmware. My router is bricked.
