LOISLANE
Aug 05, 2020Initiate
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Ro...
- Sep 23, 2021
I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
jimenezjeison11
Mar 15, 2026Aspirant
yo Tengo el mismo problema, la versión del firmware sigue mostrando V1.4.1.50_1.3.10
- StephenBMar 16, 2026Guru - Experienced User
Did you try manually downloading and installing from the web ui?
- https://www.netgear.com/support/product/r8000p
