kathyspaid's avatar
kathyspaid
Netgear Nighthawk R8500 SSID's
I created two SSID's: BOBKAT and BOBKAT1.  BOBKAT is configured for 2.4GHz and BOBKAT1 for the 5GHz.     All of my PC's show both SSID's in which to connect to the network connection screen except ...
  • Retired_Member's avatar
    Retired_Member
    Dec 01, 2015
    If a client can't see 2.4 & 5g it's usually because said client isn't dual band.
    Settings are incorrect in the client properties,
    Client drivers need updating,
    Client cannot receive the selected channel used by the router.
    Which Guest .......2.4 or 5g ....... it does make a difference. I'm guessing 2.4 seeing how the guest SSID didn't end in 5g
    User error.
