StuartSpicer
Feb 21, 2022Aspirant
Netgear Nighthawk R9000 IP Address being assigned wrong
Netgear Nighthawk R9000 Recently router rebooted and when coming back up it began handing out wrong Ip addresses. Router Firmware Version V1.0.5.40 I have set for 192.168.1.2 - 192.168.1.200 An...
microchip8
Feb 21, 2022Master
What is the R9000 connected to? If the R9000 detects another router on the network (in case yoou have a modem+router combo) it will change addreses to not collide with the gateway. Even so, if you have a modem+router, you'll be in a double NAT situation
