StuartSpicer
Feb 21, 2022Aspirant
Netgear Nighthawk R9000 IP Address being assigned wrong
Netgear Nighthawk R9000 Recently router rebooted and when coming back up it began handing out wrong Ip addresses. Router Firmware Version V1.0.5.40 I have set for 192.168.1.2 - 192.168.1.200 An...
StuartSpicer
Feb 22, 2022Aspirant
My R9000 Nighthawk is plugged directly into a Netgear CM700 Modem
and all was working before the reboot so the devices has .1 not .10 before the reboot
It is strange because most devices giving issues are hardwired into the Router (R9000)
which should be handing off the 192.168.1.X addressing scheme to them
I use subnet mask 255.255.255.000 so it should not know about handing over
192.168.10.x address
I have total of 39 Devices on network using hardwired, 2.4g and 5g
Many are hard to reset, thing like Camera, Printer, Bulbs, Plug sockets
thay get setup by Router handing addresses to them or in some cases using mobile device to setup
Thank you for suggestion and concern
Feb 22, 2022Guru - Experienced User
I'd try a full on factory reset and setup from scratch. I would also set up a smaller DHCP default IP address pool as well. Say 192.168.1.100 to .200.
