andreicri78
Oct 19, 2022Aspirant
netgear nighthawk r9000
Hello, I have a Netger Nighthawk x 10 router (R9000) and all of a sudden I am unable to connect via WIFI as the router does not broadcast the wifi anymore. The wifi signal is active via the bu...
Oct 19, 2022Guru - Experienced User
Have you logged into the router (hardwired) to see if the ssid has changed?
Or if the ssid broadcast was disabled?
- andreicri78Oct 19, 2022Aspirant
Hello. Both are active and broadcasting. I have checked that in the first place. Nothing has changed. Any other ideas?
- plemansOct 19, 2022Guru - Experienced User
Simple factory reset and reinstall?
- andreicri78Oct 20, 2022Aspirant
Did That. Same issue. I will throw it away . 100% has a failure somewhere
