andreicri78
Oct 19, 2022Aspirant
netgear nighthawk r9000
Hello, I have a Netger Nighthawk x 10 router (R9000) and all of a sudden I am unable to connect via WIFI as the router does not broadcast the wifi anymore. The wifi signal is active via the bu...
andreicri78
Hello. Both are active and broadcasting. I have checked that in the first place. Nothing has changed. Any other ideas?
Oct 19, 2022Guru - Experienced User
Simple factory reset and reinstall?
- andreicri78Oct 20, 2022Aspirant
Did That. Same issue. I will throw it away . 100% has a failure somewhere
- FURRYe38Oct 20, 2022Guru - Experienced User
So instead of throwing the router away, why not just turn OFF the wifi radios and then connect up a wired external wifi system to the R9000? I found a slightly used Nighthawk MK63 MESH system on Amazon for cheap. You could connect this system up in AP mode and still use the R9000's router portion.
- andreicri78Oct 25, 2022Aspirant
Did That and nothing changed. This is how it looks related to the WI fi issue. I have stoped and restarterd AP access point still no solution. I give up after trying everything (factory reset, reinstall, firmware update , etc) .
