cchacker
Dec 17, 2020Aspirant
Netgear Nighthawk router log file and port mapping
Netgear Nighthawk AC1900 Modle C7000v2 The log file in my router has the following entry: Description Count Last occurence Target source [LAN access from remote] from 178.62.64...
- Dec 17, 2020
> Any ideas?
UPnP? (ADVANCED > Advanced Setup > UPnP)
antinode
Dec 17, 2020Guru
> Any ideas?
cchacker
antinode please ignore my request for instructions on how to disable UPnP. I found it Advanced setup->UPnP and one click disables it.
Feeling more secure in my little network.
Don't you think this is a serious issue? Shouldn't this be disabled by default?
With this enabled it would be very easy for malware to set up a remote bot network.
