southearn
Aug 23, 2023Follower
Netgear Nighthawk router says it can support Max 32 devices per band...
My Netgear Nighthawk router specs say it can support 32 devices per band... If I add an AP via a hard-wired POE switch to one of the router's ports, do the devices on that AP count towards the 32 dev...
Kitsap
Aug 23, 2023Master
southearn wrote:My Netgear Nighthawk router specs say it can support 32 devices per band... If I add an AP via a hard-wired POE switch to one of the router's ports, do the devices on that AP count towards the 32 device limit? Or do they only count towards the AP's device limit?
Yes.
