forcemani
Mar 27, 2023Follower
Netgear Nighthawk router
My Netgear Nighthawk router specs say it can support 32 devices per band... If I add an AP via a hard-wired POE switch to one of the router's ports, do the devices on that AP count towards the 32 d...
michaelkenward
Mar 27, 2023Guru - Experienced User
forcemani wrote:
My Netgear Nighthawk router specs say it can support 32 devices per band... router.
Which router is that?
The router handles connected devices.
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
