edward78
Sep 20, 2022Aspirant
NETGEAR Nighthawk Smart Wi-Fi Router, R6700 - AC1750 Wireless Speed & netTALK Duo with builtin Wifi
What is the right way to set this up? Calls only go out most times, a nettalk reset fixes it for a short time. Nettalk tech support is no help.
Sep 20, 2022Guru - Experienced User
What modem/gateway is the router connected to?
I misunderstood and thought your nettalk was your ISP.
Its just a voip provider that connects to the router.
Try going into the router and turning of sip alg.
You can also put the nettalks ip address into the routers DMZ.
How do I set up a default DMZ server on my Nighthawk router? | Answer | NETGEAR Support
edward78
Oct 25, 2022Aspirant
We switched to the Grandstream, a Nettalk tech put in the right changes & it still deosn't work 100% of the time.
- plemansOct 25, 2022Guru - Experienced User
A grandstream? What model
- edward78Oct 27, 2022Aspirant
It is the Nettalk hardware, my dad took the sim out of his phone so it was off of the cell network & turned WiFI on then the Nettalk app still worked when I called.
- plemansOct 27, 2022Guru - Experienced User
So you're saying its an issue with your nettalk hardware and not the netgear?
Just clarifying.
