edward78
Sep 20, 2022Aspirant
NETGEAR Nighthawk Smart Wi-Fi Router, R6700 - AC1750 Wireless Speed & netTALK Duo with builtin Wifi
What is the right way to set this up? Calls only go out most times, a nettalk reset fixes it for a short time. Nettalk tech support is no help.
edward78
Oct 27, 2022Aspirant
It is the Nettalk hardware, my dad took the sim out of his phone so it was off of the cell network & turned WiFI on then the Nettalk app still worked when I called.
Oct 27, 2022Guru - Experienced User
So you're saying its an issue with your nettalk hardware and not the netgear?
Just clarifying.
- edward78Oct 28, 2022Aspirant
Yes, we had this issue with 2 Nettalk Products, oddly with our TP-Link this barely happened. The issue is the Nettalk hardware though, 1. It happened with them plugged in before the router through a switch. 2. The Nettalk app. works over Wifi, so that seems to say it is not the router.
