SWAW-Jerry
Dec 03, 2020Aspirant
Netgear Nighthawk WiFi Router Setup
I know you have to use a mobile App to configure the NightHawk routers now. My question is if I have the Netgear App on my iphone with a previous configured Nighthawk router, can I use it to configur...
- Dec 03, 2020
yes you can.
sometimes there's a screen saying to use the mobile app but if you look at the bottom of the browser window there's an option to continue using the browser.
Dec 03, 2020Guru - Experienced User
You don't have to use the app to configure router. I rarely do.
- SWAW-JerryDec 03, 2020Aspirant
So you can do it using a web interface then?
- plemansDec 03, 2020Guru - Experienced User
yes you can.
