TheAx7
Jul 26, 2021Guide
Netgear Nighthawk X10 / R9000 won't recognise admin pass & pass reset doesn't work
Hello, I've had this router (Nighthawk X10) for a while and it's worked great for the most part, but I've recently been encountering some weird issues with getting locked out of router login page...
- Jul 31, 2021
I've seen the password pop up issue when running double nats.
I'd get that issue fixed first and then see if you're still having the other issues.
TheAx7
Jul 31, 2021Guide
Hello,
Was just about to go ahead with the re-setting-up of the routers when I came back to the realisation that the R9000 I have doesn't have a DSL port hence why I had the double router set up.
So, my question at this point - would it simply be best to set up the R9000 in AP mode? Or would there still be some settings to tune inside Vodafone's router as well (even if optional to better the performance)?
Any guidance will be much appreciated!
