Dave47
Nov 18, 2023Aspirant
Netgear Nighthawk X10 AD7200 (R9000) end of service status
Hi everyone, I've got a Netgear Nighthawk X10 AD7200 (R9000) router. Its firmware is up to date as far as I've been able to determine (version 1.0.5.42). This is both from the router itself sayin...
- Nov 19, 2023
It's EoL.
I highly recommend for continued FW support, go over to Voxels 3rd party FW site and check it out. What's loaded on my R9000 now:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-71hf.87157/
Nov 19, 2023Guru - Experienced User
It's EoL.
- Dave47Nov 20, 2023Aspirant
FURRYe38,
Thanks for the info. Thought that would be the case.
I'll look into the info at the links you've provided.
Dave
- FURRYe38Nov 20, 2023Guru - Experienced User
- schumakuNov 20, 2023Guru - Experienced User
FURRYe38 wrote:
It's EoL.
Are you representing Netgear providing such misleading information, or is Netgear once more not up2speed?
Checking these minutes again on https://www.netgear.com/about/eos/ does clearly not list the R9000/R8900 for example (November 20, 2023 as of writing):
The web site needs updating. 🙄
