micmac2013
Oct 31, 2024Aspirant
Netgear Nighthawk X10 Router Only 60GHz Light Blinking and Won't Connect to PC
Hi everyone, I'm having an issue with my Netgear AD7200 Nighthawk X10 router. When I turn it on, only the 60GHz 802.11ad light blinks, and the router doesn’t connect to my PC. I’ve tried resetting i...
Oct 31, 2024Guru - Experienced User
Do you have a connection to the routers web page at 192.168.1.1 with a ethernet connected PC?
Press the reset button for 15 seconds then release then give about 1 minute, should get a web page there.
Had this router been working?
Any idea of the firmware version loaded on the router?
Had other non NG 3rd party firmware been loaded on it?
Do you have a PC that supports the 60Ghz WiFi AD signal coming from the router?
Not many devices were supporting of 60Ghz and there was limited WiFi adapters that supported 60Ghz.
60Ghz was a complete different spec that was separate from the WiFi N and AC 2.4 and 5Ghz radios.
