micmac2013
Oct 31, 2024Aspirant
Netgear Nighthawk X10 Router Only 60GHz Light Blinking and Won't Connect to PC
Hi everyone, I'm having an issue with my Netgear AD7200 Nighthawk X10 router. When I turn it on, only the 60GHz 802.11ad light blinks, and the router doesn’t connect to my PC. I’ve tried resetting i...
Kitsap
Nov 01, 2024Master
If you find you do not have any devices that can connect to the 60 GHz Wi-Fi band, it would be beneficial to go into the advanced settings and disable the 60 GHz radio. By leaving it on and not connecting to anything, you are needlessly burning power, generating heat, and polluting the radio frequency environment in your home.
