craigressler
Jul 28, 2017Aspirant
Netgear Nighthawk x4 ac2350
I want to know if the Firewall (s) on the Nighthawk x4 ac2350 model R7500v2 use stealth porting, and if this is turned on by default. Thank you.
- Aug 07, 2017
Hi craigressler,
The router does not use the stealth porting type of firewall. R7500v2 will always response with “reset” packet if client send packet to non-opened port.
JamesGL
Aug 13, 2017NETGEAR Employee Retired
Hi craigressler,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
craigressler
Aug 14, 2017Aspirant
Thank you James, your answer was very helpful. Have a great day.
- JamesGLAug 14, 2017NETGEAR Employee Retired
Hi craigressler,
Thank you for the feedback. We encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
