MrxAD81's avatar
MrxAD81
Follower
Oct 30, 2016
Netgear Nighthawk X4S AC2600 compatible with ADSL/VDSL
Hello,   I own the NetGear Nighthawk X4S AC2600 Smart Router. I wonder whether the router is suitable for support of "annex-j" and "1TR112" standards for IP VDSL/ADSL via Deutsche Telekom (provide...
  • ElaineM's avatar
    Nov 02, 2016
    Hi MrxAD81
    Welcome to the community!
    You should be looking for an ADSL Modem Router. The one that you have which is R7800 is only a router.
    You may check out the following models below:
