raschurchill100
Aug 01, 2022Aspirant
Netgear Nighthawk x4s R7800 - periodic crash (white lighst stay on when crashed)
Hi All, Normally this router has been really stable however over the last week it crashes once a day Firmware V1.0.2.90 (standard netgear not a 3rd party firmware) Access Point mode ethernet...
Aug 01, 2022Guru - Experienced User
What all devices do you have connected to it?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Does the top of the router feel extra warm or hot to the touch when this happens?
