Swindonpete
Nov 23, 2020Guide
Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender and BT Broadband
Hi All - Could anyone help me - I've got a BT broadband connection with their latest router and I'm looking to buy a Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender Can anyone confirm it will ...
Nov 23, 2020Guru - Experienced User
It works for many but don't use the wps method of setup. Use the installation assistant.
What actual router from them do you have.
Swindonpete
Nov 23, 2020Guide
Hi Thnks for the quick response. I have the Smart Home Hub the one BT just sent me? Does that help?
- plemansNov 23, 2020Guru - Experienced User
Not really. there should be a model number on the label.
- SwindonpeteNov 23, 2020Guide
It says BT Hub6-27FW It also says Type A too?
thanks again for helping me with this.
It *should* work. Just don't use WPS to set it up.
I say should because ISP supplied routers aren't known to be that great at playing well with others.
