Swindonpete
Nov 23, 2020Guide
Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender and BT Broadband
Hi All - Could anyone help me - I've got a BT broadband connection with their latest router and I'm looking to buy a Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender Can anyone confirm it will ...
Nov 23, 2020Guru - Experienced User
Not really. there should be a model number on the label.
Swindonpete
Nov 23, 2020Guide
It says BT Hub6-27FW It also says Type A too?
thanks again for helping me with this.
- plemansNov 23, 2020Guru - Experienced User
It *should* work. Just don't use WPS to set it up.
I say should because ISP supplied routers aren't known to be that great at playing well with others.
- SwindonpeteNov 23, 2020Guide
Thanks very much. Is there a simple guide to the setting up steps without using WPS please?
there's guides and even a video on the support site. I think its the 4th video on the support site. it says how to setup using installation assistant.
https://www.netgear.com/support/product/EX7700
