agmcconaghy's avatar
agmcconaghy
Netgear NightHawk X6 AC3200 R8000 - OpenVPN – Connection Timeout
Hi all,  I'm new to the forum and hoping someone has come across the same problem that I have. In a nutshell, the VPN functionality has stopped working on my R8000, pretty much coinciding with th...
  • agmcconaghy's avatar
    Jan 06, 2019
    All solved due to this handy link - no idea why it isn't easily accessible from the Netgear Genie.
    This link allows you to reset the certificates which you'll need to do once the firmware is up to date.
    Then follow the setup steps in the usual way.
    http://192.168.1.1/openvpn_crt_check.htm
