SuperHyphen
Jun 05, 2023Aspirant
Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
I recently inherited the Netgear Nighthawk X6 R8000 and its missing the label with all the information including the serial number. I already hit the factory reset button and I am directly connec...
Jun 05, 2023Guru - Experienced User
Try a different browser. MS Edge, Firefox or Opera,
Be sure all browser caches are clear before the reset.
Enter the routers web page at 192.168.1.1 not 2.1 after the reset. Be sure the press the reset button for 10-15 seconds then release.
- SuperHyphenJun 05, 2023Aspirant
After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
This was a bit frustrating to say the least.
I am in the admin portal, question is where can I find the serial number in the admin portal?
I would like to not repeat the process the next time I need to run through a reset.
Thanks,- FURRYe38Jun 05, 2023Guru - Experienced User
Walk thru the setup wizard and be sure to write down important information for safe keeping. The setup wizard will guide you thru and setup a log in PW for the admin log in.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - KitsapJun 05, 2023Master
SuperHyphen wrote:After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
Thanks,You can't.
Log in to your user interface using 192.168.1.1/hidden_info.htm. Note the underscore character between hidden and info. The serial number should be on the second line of the screen. The word serial did not make it cleanly through translation.
- KitsapJun 07, 2023Master
As an addendum, if you install the Nighthawk mobile application, I use Android, and connect to your router you can get the serial number of your router. Go to Menu -> About and it will provide your router serial number.
