SuperHyphen
Jun 05, 2023Aspirant
Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
I recently inherited the Netgear Nighthawk X6 R8000 and its missing the label with all the information including the serial number. I already hit the factory reset button and I am directly connec...
SuperHyphen
After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
This was a bit frustrating to say the least.
I am in the admin portal, question is where can I find the serial number in the admin portal?
I would like to not repeat the process the next time I need to run through a reset.
Thanks,
Jun 05, 2023Guru - Experienced User
Walk thru the setup wizard and be sure to write down important information for safe keeping. The setup wizard will guide you thru and setup a log in PW for the admin log in.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
