SuperHyphen
Jun 05, 2023Aspirant
Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
I recently inherited the Netgear Nighthawk X6 R8000 and its missing the label with all the information including the serial number. I already hit the factory reset button and I am directly connec...
Kitsap
Jun 05, 2023Master
SuperHyphen wrote:After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
This was a bit frustrating to say the least.
I am in the admin portal, question is where can I find the serial number in the admin portal?
I would like to not repeat the process the next time I need to run through a reset.
Thanks,
You can't.
Log in to your user interface using 192.168.1.1/hidden_info.htm. Note the underscore character between hidden and info. The serial number should be on the second line of the screen. The word serial did not make it cleanly through translation.
Kitsap
Jun 07, 2023Master
As an addendum, if you install the Nighthawk mobile application, I use Android, and connect to your router you can get the serial number of your router. Go to Menu -> About and it will provide your router serial number.
