icpruleuk
Sep 01, 2021Aspirant
Netgear Nighthawk x6 R8000 failing to load websites
On both my PC and phone websites fail to load then I refresh the page and they load, youtube videos and netflix fails to load the video stills just apearing as grey boxs and my cctv keeps loosing con...
Sep 01, 2021Guru - Experienced User
Since installing the new router or since updating firmware?
What firmware version are you on?
What modem/gateway are you connected to?
- icpruleukSep 01, 2021Aspirant
Since installing the new router, the nighthawk is connected to my virgin media superhub 3 which is running in modem mode, the firmware virsion of the nighthawk is 1.0.4.74.
Followed all the standard setup, I'm pretty tech savvy and have tried all the usual things like resetting both superhub and nighthawk to factory, my PC is connected wirlessly but only 1m away from router and if I disconnect the nighthawk and connect directly to superhub the issues stop.
- plemansSep 01, 2021Guru - Experienced User
The superhub is a modem/router combo device in itself.
https://kb.netgear.com/30186/What-is-Double-NAT
it causes a double nat. I've read of the rare person being able to get their superhub in passthrough/modem only successfully.
But others have either had to resort to putting the netgears IP address into the superhubs DMZ or using the netgear in access point mode.
the superhub is already running in modem mode only
