toonfan11's avatar
toonfan11
Netgear Nighthawk X6 R8000 using a nighthawk s8000
Hello, im new on here so please be patient, at the moment I’m using a nighthawk s8000 switch with my virgin super hub 3, I have bought a nighthawk r8000 router, should I just use the r8000 with my ...
  • toonfan11's avatar
    toonfan11
    Sep 07, 2018
    Hi sorry for the delay in replying, been away, thank you for replying, no i dont need extra ports now, just thought they might be an advantage to having the switch connected, i have since removed the switch
